贴吧教程贴,用这个方法成功修改D大魔改的Lenovo ThinkStation P310隐藏bios选项值。
目前碰到一个问题是想要修改bios的cpu核心电压为固定电压,这个选项使用amibcp查看注释为“Specifies the Override Voltage applied to the IA Core domain.This voltage is specified in millivolts.Uses Mailbox MSR 0x150,cmd 0x11.Range 0-2000 mV." 不知道如何使用setup_var修改这个Numeric的值。 0x4F454 One Of: Core Voltage Mode, VarStoreInfo (VarOffset/VarName): 0x699, VarStore: 0x1, QuestionId: 0xB77, Size: 1, Min: 0x0, Max 0x1, Step: 0x0 {05 91 5E 13 5F 13 77 0B 01 00 99 06 10 10 00 01 00}
0x4F465 One Of Option: Adaptive, Value (8 bit): 0x0 (default) {09 07 6C 13 30 00 00}
0x4F46C One Of Option: Override, Value (8 bit): 0x1 {09 07 6D 13 00 00 01}
0x4F473 End One Of {29 02}
0x4F475 Suppress If {0A 82}
0x4F477 QuestionId: 0xB77 equals value 0x0 {12 06 77 0B 00 00}
0x4F47D Numeric: Core Voltage Override, VarStoreInfo (VarOffset/VarName): 0x69A, VarStore: 0x1, QuestionId: 0xB78, Size: 2, Min: 0x0, Max 0x7D0, Step: 0x1 {07 94 60 13 61 13 78 0B 01 00 9A 06 10 11 00 00 D0 07 01 00}
0x4F491 Default: DefaultId: 0x0, Value (16 bit): 0x0 {5B 07 00 00 01 00 00}
0x4F498 End {29 02}
这个mailbox寄存器是什么意思?是否电压值储存在寄存器地址0x150?cmd 0x11又是什么意思?
