TA的每日心情 | 无聊 2022-8-30 23:11 |
楼主 |
发表于 2020-1-12 22:36:10
显示全部楼层
PS C:\Users\vv\Desktop\TS860M5_BIOS_4.0.04_20190424\UVETool\InsydeH2OUVE_x86_WINx64_200.00.01.00> .\H2OUVE-W-CONSOLEx64.exe -sv var2019.txt
Now Parsing File From var2019.txt.
Succeed to read var2019.txt file.
Variable Index[001]: Set failed!
Variable Index[002]: Set failed!
Variable Index[003]: Set failed!
Variable Index[004]: Set failed!
Variable Index[005]: Set failed!
Variable Index[006]: Set failed!
Variable Index[007]: Set failed!
Variable Index[008]: Set failed!
Variable Index[009]: Set failed!
Variable Index[00a]: Set successfully!
Variable Index[00b]: Set successfully!
Variable Index[00c]: Set failed!
Variable Index[00d]: Set successfully!
Variable Index[00e]: Set successfully!
Variable Index[00f]: Set successfully!
Variable Index[010]: Set successfully!
Variable Index[011]: Set successfully!
Variable Index[012]: Set successfully!
Variable Index[013]: Set successfully!
Variable Index[014]: Set successfully!
Variable Index[015]: Set successfully!
Variable Index[016]: Set successfully!
Variable Index[017]: Set successfully!
Variable Index[018]: Set successfully!
Variable Index[019]: Set successfully!
Variable Index[01a]: Set successfully!
Variable Index[01b]: Set successfully!
Variable Index[01c]: Set successfully!
Variable Index[01d]: Set successfully!
Variable Index[01e]: Set successfully!
Variable Index[01f]: Set successfully!
Variable Index[020]: Set successfully!
Variable Index[021]: Set successfully!
Variable Index[022]: Set successfully!
Variable Index[023]: Set successfully!
Variable Index[024]: Set successfully!
Variable Index[025]: Set successfully!
Variable Index[026]: Set successfully!
Variable Index[027]: Set successfully!
Variable Index[028]: Set successfully!
Variable Index[029]: Set successfully!
Variable Index[02a]: Set successfully!
Variable Index[02b]: Set successfully!
Variable Index[02c]: Set successfully!
Variable Index[02d]: Set successfully!
Variable Index[02e]: Set successfully!
Variable Index[02f]: Set successfully!
Variable Index[030]: Set successfully!
Variable Index[031]: Set successfully!
Variable Index[032]: Set successfully!
Variable Index[033]: Set successfully!
Variable Index[034]: Set successfully!
Variable Index[035]: Set successfully!
Variable Index[036]: Set successfully!
Variable Index[037]: Set successfully!
Variable Index[038]: Set successfully!
Variable Index[039]: Set successfully!
Variable Index[03a]: Set successfully!
Variable Index[03b]: Set successfully!
Variable Index[03c]: Set successfully!
Variable Index[03d]: Set successfully!
Variable Index[03e]: Set successfully!
Variable Index[03f]: Set successfully!
Variable Index[040]: Set successfully!
Variable Index[041]: Set successfully!
Variable Index[042]: Set successfully!
Variable Index[043]: Set successfully!
Variable Index[044]: Set successfully!
Variable Index[045]: Set successfully!
Variable Index[046]: Set successfully!
Variable Index[047]: Set successfully!
Variable Index[048]: Set successfully!
Variable Index[049]: Set successfully!
Variable Index[04a]: Set successfully!
Variable Index[04b]: Set successfully!
Variable Index[04c]: Set successfully!
Variable Index[04d]: Set successfully!
Variable Index[04e]: Set failed!
Variable Index[04f]: Set failed!
Variable Index[050]: Set successfully!
Variable Index[051]: Set successfully!
Variable Index[052]: Set successfully!
Variable Index[053]: Set successfully!
Variable Index[054]: Set successfully!
Variable Index[055]: Set successfully!
Variable Index[056]: Set successfully!
Variable Index[057]: Set successfully!
Variable Index[058]: Set successfully!
Variable Index[059]: Set successfully!
Variable Index[05a]: Set successfully!
Variable Index[05b]: Set successfully!
Variable Index[05c]: Set successfully!
Variable Index[05d]: Set successfully!
Variable Index[05e]: Set successfully!
Variable Index[05f]: Set successfully!
Variable Index[060]: Set successfully!
Variable Index[061]: Set successfully!
Variable Index[062]: Set successfully!
Variable Index[063]: Set successfully!
Variable Index[064]: Set successfully!
Variable Index[065]: Set successfully!
Variable Index[066]: Set failed!
Variable Index[067]: Set failed!
Variable Index[068]: Set failed!
Variable Index[069]: Set failed!
Variable Index[06a]: Set failed!
Variable Index[06b]: Set failed!
Variable Index[06c]: Set failed!
Variable Index[06d]: Set failed!
Variable Index[06e]: Set failed!
Variable Index[06f]: Set failed!
Variable Index[070]: Set failed!
Variable Index[071]: Set failed!
Variable Index[072]: Set failed!
Variable Index[073]: Set failed!
Variable Index[074]: Set failed!
Variable Index[075]: Set failed!
Variable Index[076]: Set failed!
Variable Index[077]: Set failed!
Variable Index[078]: Set failed!
Variable Index[079]: Set successfully!
Variable Index[07a]: Set successfully!
Variable Index[07b]: Set successfully!
Variable Index[07c]: Set successfully!
Variable Index[07d]: Set failed!
Variable Index[07e]: Set failed!
Variable Index[07f]: Set failed!
Variable Index[080]: Set failed!
Done. |
